Reporting back in. I expect to finish up this project over the next two weeks. We had a pretty cold winter, so I let this project take its time. Uncoupling the transmission and shaft proved to be a bear. Getting the set screws loose from the coupler required a couple of applications of PB Blaster, spread out over three visits to the boat on the hard before the first screw would turn the slightest bit. Silly me, I thought I had made great progress, but still had to get the coupling off the shaft after the set screws were removed. Hah! I used a puller, which was an absolute necessity, and I found several ways to get my left hand and arm over the fuel pump, past the manifold and the heat exchanger and related hoses and back to the shaft while the right arm wrapped between the water heater hoses and down. I had to explain the resulting bruises to my physician, lest my spouse be implicated unfairly. The biggest challenge was that there was so little clearance between the two halves of the coupler (one still on the transmission, and the other on the shaft), that I couldn't get the puller in between them. Eventually, I cut off the bellows on the old PSS that was still on the shaft so that I could gain more room. Then I worked through a series of spacers between the puller and the shaft over many days, starting with a 3/4" nut, moving to a #13 socket, and then a longer socket. Changing spacer lengths meant loosening the four bolts all over again, and then tightening. Finally, I succeeded in getting the coupler off the shaft and removing the rest of the old PSS. The shaft had some scoring where it went through the cutlass bearing, so I sent it off to a shop to have them evaluate and to make sure it was true. I just got it back this week, and I it passed inspection. Pulling the old cutlass bearing proved challenging. Like others, I ended up having to hacksaw through from the inside, which Nigel Calder suggests as a reasonable last resort. The new bearing is in the freezer, to be installed this weekend.
