    Adventures & Follies
    November Meeting Info
35-2 Head photos?
RonmryD
Hello forum!
I have been tasked with replacing a torn-out head in the 35-2. I have scoured the forums and web for photos of the main cabin floor to head lip detail. All the photos are from the head up. I need to see what shape the "shower pan" is and how the head door seals to it.
Does anyone have photos to share?
Thank you.
Aaron
Seattle
exoduse35
I am not exactly sure what you are asking for. I will be glad to shoot you pictures of anything you need next week when I am at the boat. The shower pan is part of the cabin sole. It is flush with the sole of the main cabin. There is a fiberglass lip across the doorway that is the same height as the seam between the glass and woodwork of the walls (about 3 inches). The platform for the head is at the same height and begins at the doorway. The aft edge is the glass below the bulkhead and the outboard lip is formed below the cabinets. the pan is square (or rectangle). Is this what you need details of? Let me know, Edd
RonmryD
the lip is it
Thanks for the offer Edd!
As the prints I have are just line drawings from the manual and sales brochures, I have no dimensions or details of that lip between the head floor and the main cabin. Is it thin or thick? Does the door come to rest over the lip or against the cabin side? Is there a drain in the pan? (I am assuming that one but it tells you just how many people shoot pictures of the floor of their head!)
exoduse35
The lip is under the door and about as wide. The drain is about 3" in from the lip and about 3 inches from the aft wall. I will be sure and place a tape measure in the photos for you. It sounds like someone has cut the floor out if you need these pictures. If that is the case you have an unenviable job in front of you. You may be just as well of to have one of us make you a mold from ours then make a piece from that. Do you have any pictures of what you are starting with? Edd
RonmryD
Thanks again. The boat was stripped to the ribs to make her a racing goddess. So what I have is the fiberglass hull. This picture is looking aft.
exoduse35
here are som pics. sorry for the mess but it is under construction. Edd
exoduse35
here is some more
exoduse35
and a couple more. Hope you find everything you need, if not just let me know and I'l get them for you. Edd
RonmryD
Thank you so much. I didn't get an email about your post so I didn't see them until today (hence the long over due thanks).
Looks like I am going to use EPS foam as a form base and fiberglass over it to get the shape shown. Is your heads floor integral to the hull or is it a separate piece?
exoduse35
the entire floor is one piece. I believe that it was placed into the hull then the cabinetry work was set in then the deck added last. You should be able to see where it was cut away from the sole panel that runs from the companionway to the aft face of the V berth. I think it is only "attached" to the hull on the port side and then only at the head pan and at the nav station. The rest of the sole seems to "float" on the support structure beneath and held in place by the cabinets. Edd
