austinmotion
The forward storage compartments over the v berth of my E23 are backed with an unattractive sticky material. From reading the original brochure it seems this sticky material likely held foam-backed naugahyde trim. It appears sometime over the last ~30 years this trim was pulled out. If I'm correct, the easiest fix would be to just pull this sticky material out. I'm assuming (after some goo be gone) this would leave white fiberglass-backed storage compartments like the main compartment. Otherwise I'd have to source matching trim pieces and stick them in. Does anybody have any suggestions? Thanks!
Ivan
Ivan
