We are looking to do an upgrade to the rigging that requires an answer to two questions. We would like to add a removeable inner forestay for using a relatively small hank on jib (maybe an 85?) on upwind legs in strong wind -- we live in San Francisco. We would also use this for hanking on a proper storm jib if/when we find ourselves in extreme conditions.
The mast (original) has two welded tabs. One of them is obviously for a spinnaker pole topping lift, I'm assuming the other one (higher up) is for just this purpose.
So here are the two questions:
1) If we use the upper tab for attaching the inner forestay, would we need to use running backs? We would certainly like to avoid this if possible. One sail plan drawing I've seen for this boat seems to show an inner forestay, but with no running backs detailed.
2) I have attached a heavy duty padeye on the deck just forward of (and adjacent to) the forward-most bulkhead (chainlocker). I have the four bolts for this padeye going through a fairly large (6" x 10" x 1/4") stainless steel backing plate. This is currently being used for the foreguy attachment point. If I welded on an extension to this plate at a right angle, (so that it is parallel to and right against the bulkhead) and through-bolted it to the bulkhead, would this be strong enough for the foreguy? Or would I have to glass in a tie-rod to the bow? I'm hoping the former is strong enough, but I don't want to risk damaging the deck.
Anyone of any experience with this?
