gareth harris
I am about to cut new through hulls for drains for the aft well in the cockpit, keeping the old through hulls for the forward well only, so as to speed up drainage should a large wave flood both wells. I intend to cut two through hulls just above the (level) water line, and cross the hoses to the far corners of the well deck.
I am sure I have read from 35-3 owners (but can not find it now with a search) that they have had a problem with water backing up when heeled over: what arrangement gives that problem?
By measuring, it looks as though the corner of the cockpit will fall below the water line at about 30 deg of heel, I am guessing that with surging waves water may come up through the drains at somewhat less heel than that. With the arrangement I have described, I can cut the holes in the hull anywhere in a curve from about 18" out from, and abeam, the rudder stock; to 15" out on a 45 deg line aft of abeam the rudder stock. I doubt it would make much practical difference where on that curve I cut it.
Has anyone tried this, or thought of a better arrangement?
Gareth
Freyja E35 #241 1972
Gareth
