Posting for anyone else who runs into this:
Problem:
My AIS has had a "ghost vessel" on the chartplotter since it was all installed.
[Raymarine Axiom II Pro; Standard Horizon VHF with AIS receive; Vesper 8000 AIS transmit/receive.]
This "ghost vessel" has trailed the boat like a dinghy on the plotter, trailing further behind as boat speed increased. The "ghost" has my own MMSI, so obviously this was a set-up problem. The (otherwise reputable) folks who installed it all did not know what the issue was, but also had trouble seeing it since at the dock the ghost vessel is not obvious against the larger icon for "My Boat".
The presence of the ghost made it impossible to use the proximity (CPA) alarm on the AIS offshore, negating most of the value (to me) of the AIS -- the nearby ghost would cause any proximity / CPA alarm to trigger constantly, forcing me to shut it off.
Solution:
It turns out the Standard Horizon VHS receives AIS and... puts it onto the network with the boat's MMSI. It has not way to ID this on the network as 'My Boat'. The Raymarine chartplotter can ID 'My Boat' (e.g. as put out onto the network by the Vesper AIS) and not trigger alarms off it, but has no way to exclude any MMSI's... including my own, and it cannot recognize my own MMSI as 'My Boat'. Thus it plots both. What the Vesper can do internally I have not investigated yet.
Issue: SH did not do the firmware for their radio correctly. Raymarine did not do the software for their chartplotter correctly. Both should have ways to ID your own vessel's AIS. They do not play together well.
Solution: Disconnect the Standard Horizon VHF from the network. Problem solved. I still have it as backup GPS (displays on radio and handset), it will still work for DSC/emergency signal, but if I want it back on the network (e.g. if my other GPS or AIS fail) then I need to reconnect the network plug for it (not difficult).
Anyway, if anyone else has run into this, here is a solution -- took a long time and involvement of a second (much more skilled) person to solve this on my end.
Problem:
Solution:
