Jeez...just asking a question. I didn't question the veracity of your story; I just asked if anyone else had the same experience or knew how many cases had been reported.
Maybe it was a problem that only manifested itself on the M25 engine, but since the M18 used the same bracket, Universal recommended the change for the M18 as well.
You yourself even cite a failure of the new bracket in a July 2008 post on the Catalina forum:
"I just (literally last night) heard of a new style bracket failure on a friend's M25XP (1988) boat, which dropped his alternator out of the loop by failing at the top of the bracket."
How many failures of the "new bracket" have been reported? Seems like just about any bracket in that application is "prone to failure."
Hi, Mark
My purpose in writing as much as I have is to help other people out, and did not intend to be other than helpful by passing on this information.
I would appreciate a link to the note you said I made, so I can read it in context. Also, in the 12 or more years I've been doing this I have heard of NO (other?) new bracket failure on M25 engines. None, on our C34 board and the C36 board.
The basic point is and always has been, that as I wrote in that article, the OLD support is a
casting. They never exhibit any signs of stress or bending. Castings just SNAP!
I have heard of dozens of these breaking, and even Universal changed it, for good reason. I have hull #224, 1986, a good friend has #214. I convinced him to do this and replace his exhaust riser, before his failed and years after both of mine did. I wanted him to do preventive maintenance, not wait for a failure to have to do it.
For you others listening in here, please, please, please read and perhaps reread that link about the bracket. And look at the pictures. The new bracket connection to the engine doesn't go anywhere near the front of the engine, it's bolted on to the studs through the coolant manifold on the port side.
If the new bracket fails it would be in the underneath support of the alternator and let it slip down, rather than completely crashing down towards the engine and into the oil filter because the old casting held it up from the top.
I'd betcha there are dozens of M25 engine blithely sailing around the world with the old casting. Mine broke but I had the parts to fix it as the story says. Do you? Is it worth it happening to you? I sure hope not.
And now that I've just learned it's on M18s as well, there twice as many engines out there prone to failure that could be avoided.
We, too, have limited room on the port side where the alternator goes. All of us who've corrected the support error have had room for the alternator. You may not. But if you don't you can hook up the new bracket to the engine, which is the main new support in compression, and just get a slightly different adjusting arm from a local machine shop. This will serve the allow you to adjust the alternator as far inboard as it started on the old bracket. Think about it: the geometry of the upper inboard end of the alternator with the through bolt doesn't move much to port, so all you have to change is the "swing" of the alternator. This has always had to be balanced literally "against" that danged hose underneath that goes to the HX.
Just tryin' to help is all I said.
However, I just have to add that this is for your safety, that of your crew and your family. When it happened to me I was at a friend's dock. Coulda happened to me "out there."
I hope it doesn't happen to any of you, even if you choose to ignore the history and the warning, from both the builders of the engine and your fellow boaters.
I was so concerned about this that I helped install the upgrade on our friend's Ericson 32. I musta hassled him so much he bought one! In their case, we spent most of the day removing the shorter studs he had on his engine and replacing them to fit the bracket. My studs were long enough that I was spared that effort. As I recall, and from the picture, the new package has longer studs. Don't take 'em out if ya don't have to. Also have a dockmate with a C36 who didn't know about it.
Since this is a recurring issue, one of our members was kind enough to suggest our Critical Upgrades page and I'm glad he did. All of the worst things that can bite ya, right in one place.
We again invite you to use "our facilities" on our website anytime you wish, and feel free to join us on our board.
I've certainly learned a lot from listening to all of you since I signed up here. Thanks so much.
Stu
