I am in the process of revising my electrical system to designate dedicated start and house battery banks. A Blue Sea Systems BatteryLink charger will be installed, with its integral ACR (Automatic Charge Relay), along with a Blue Sea "Dual Circuit Plus" battery switch. In such a system, the start battery is dedicated to starting duty, but in event of failure of that source, the house bank may be called on, with the battery switch set to combine both banks.
ABYC calls for a fuse to be installed within a few inches of any connection to a battery, except for a conductor connected to the engine starter motor. So all leads from the house bank should likewise be fused to protect against a short circuit condition.
And that brings me to my question. I have a 1/0 cable from the house bank to the battery switch, and generally, that conductor serves nothing more than the house panel, and so should be fused. But in event of a failure of the starter battery (?), moving the battery switch to "combine" or "both" will allow the house bank to serve the demand of the engine starter motor (as it does presently). So what fuse will be adequate to carry that load? Nigel Calder, in his Boat Owner's Mechanical and Electrical Manual suggests that a pair of jumper cables could serve in this case in lieu of the battery combine/both switch. But I'd rather not need to pull out the jumpers if a suitable fuse at the house bank will let me simply switch to combine/both, since that's what my reflexive response would be.
In summary (whew!) with failure of the start battery, the house battery can be switched to supply power to the starter. ABYC would like to see a fuse in that house conductor, so what size fuse would likely work to power the start motor?
