Sailing ixion
Hi everyone. Work is progressing on rehabbing our E34-2. One of the projects on my list is redoing the bottom since the antifouling was failing (large chips/flaking).
Im using Aqua Strip to do the majority of the job and then plan on sanding the rest to get as fair a surface as I can. But I’m running into a bit of a problem. It looks like sometime in the life of this boat someone used barrier coat on top of old antifouling and it’s that old antifouling that is failing, but it isn’t universal. Because of this the paint thickness is varying greatly leaving a very uneven unfair surface. Should I remove the barrier coat and get all the way to gelcoat or at the very least fairing compound?
im looking to fix this the right way, but I don’t want to needlessly overwork the problem. I feel like I should get to a point where all the antifouling is gone and start clean even if I run into a barrier coat. Am I making more work for myself?
