Efficiency of solar panels
Just a comment on the relative efficiency of solar panels ... typically solar panel efficiency is measured in terms of watts output per square foot of surface area but there are other considerations. If you measured output per pound of panel for example, the flexible panels are more efficient than rigid panels. Also you need to consider windage. The flexible panels offer a much smaller wind profile than rigid panels.
It just depends on how you use the boat and the panel. Racers that stow the panel on board when racing for example might prefer the lighter weight flexible panel. Cruisers that don't care about weight and windage might prefer bigger rigid panels.
Just throwing a little gas on the fire.
