Bill Sanborn
A quick thought.
Check the centrifugal advance in the distributor. It is located under the plate that the points are mounted on. The "levers" should move freely under spring tension.
Seems like this should still need to operate the same with an electronic ignition.
Spray with WD40 if frozen. Moyer has replacement springs.
Good luck.
Good luck.
