Hello,
Well for my first project I want to remove the Tiller / Rudder and repaint it. This will be a test run (for doing the entire bottom this spring) and first time using bottom paint for me.
I do not know what type of paint is on the bottom currently. (Hey Sven what type of paint is on the bottom / tiller?).
1) Any Advice on removing the tiller from a E23? Aside from tying a rope to it before I undo bolts
2) What type of paint do you recommend? or What brand? Is it best to stick with the same products from the same brand? (The boat is in an area of the marina which does not have very much current flowing through)
3) I will be sanding this by hand, as not to burn too deep with my power sander, Garage has a heater so I can make it room temp +, Its ventelated and I can leave it out there for several days to dry.
4) Anything else before I get started? I'm sure I will have questions down the road, but plan on retrieving the tiller & picking up some paint this weekend.
