Paint rudder light color or make it a storage cover.
Here's a little tidbit that you might want to consider. A common thing that happens on rudders when sitting on the hard is dry blisters. By simply painting your rudder a light color you will reduce the frequency of dry blisters.
Dry blisters happen when the Sun hits a dark painted rudder and heats air trapped in dry spots in the laminate layers. The result is a dry blister as the dry layers separate as the air pressure increases with the heating. For some reason as the air cools later the blisters don't necessarily subside.
Dry blisters should not be ignored. Any air spaces in the laminate invite water to collect and then lead to the dreaded wet blisters, acid formation, and further breakdown of the laminate structure.
One way to repair the dry blister involves drilling a few small holes in the top and bottom of the blister to release the air. That will collapse the blister. The holes shouldn't go all the way into the core of the rudder. They should just be into the laminate. Then you need to carefully inject a very thin expoxy called penetrating expoxy into the bottom hole until it escapes the top hole, plug the bottom hole and inject into the top hole, then plug the top also. Then the holes need to be filled with a water resistant filler before barrier coat and anitfouling.
Validity of the epoxy relamination effort can be tested after drying of the epoxy by tapping such as what a surveyor does to find delamination. It takes some practice but can be done. Surveyors are supposed to use a phenolic hammer so the gelcoat won't be damaged. For a few dry rudder blisters repairs, I've tapped with the plastic handle end of a small screwdriver. The sound difference is hard to describe but obvious when you have both good and bad laminate to compare.
As prevention it is a good idea to paint the rudder a light color such as white or gray regardless of the color of the rest of the boat's bottom. This will significantly increase the reflection of the Sun's light and reduce the absorption of heat by the paint thereby reducing dry blister pressure.
You may even notice some boats on the hard have special loose fitting light colored covers for the rudder itself. These are for keeping the rudder cool also.
-- neal
omgirl said:
Forgot to ask this on my last post... any recommendations on bottom paint? She is in pretty good shape and we just will need to lightly sand and re-apply.
Also - what color looks the coolest? Her hull is white with navy blue and green stripe.
Thanks!
