Kevin Johnston
When I purchased my E27 it had a broken strut (FYI - the strut is the bronze fitting that has a bearing in that that the shaft pass through and right before the propellor attaches to it). I believe the purpose of the strut is to stablizes the shaft.
I had it repaired my first year I owned the boat. With it broken reverse is not easy going but it works. The boat has a folding prop and it has some difficulty in rough water when it is under power when the strut is broken. The strut is broken again, so apparently the weld to make the repair did not hold.
Is this a common problem? Next time the boat is hauled, is there any other better way to make the fix?
