Broken Alternator Wire = "Entropy"
The constant decay of everything to a lower level of order... in the universe... or something like that.
So we were motoring home for 5 wind-less hours, one day last week. 'Twas the finish of a nice little vacation trip down the river to the sea and back.
I soon note that the E-meter shows only battery voltage, and not the usual 14 volts. Hmm. After a night at a down river city guest dock w/o shorepower, it should show some charge for a half hour or so. Hmm...
Engine runs fine, and the belt goes round 'n' round. We slow down the revs and I gingerly touch each wire on the alternator. Sparks fly from the + output.
Since the engine will run fine as long as the belt goes 'round to keep the raw water pump happy, we continue home.
Yesterday I got the alternator off, and the wire crimp on the #10 orange wire broke off. I drive over to Bill's shop, PMX inc, that does the bulk of the marine alternator/starter work in our fair city. He confirms that when the wire, breaking strands over the years, lost its continuity for a second, diodes were either fried or will fail soon. For under $200, the Motorola 55 amp alternator will be rebuilt and handed back to me, the clueless owner, in about a week.
Lesson (re-) learned: constant vibration, over time, will work-harden wires and they *will* fail. This will then lead to other expense and inconvenience.
Well, Duh!
Anyhoo... it is really past time to start to address some of the rats' nest of old wire splices around the starboard side of the Universal.
That is the one of the last remaining problem areas inherited from the prior owner of this boat, because that side the engine is really hard to get at on our model boat. (That's my only sorry-a__ excuse and I'm sticking to it!)
Upon request, Bill rebuilds these alternators for external regulation, but unless you are really going cruising and spending weeks on passage-making, he sees no reason to do this. "If it met your needs from 1988 to 2007, why change now?"
Loren in PDX
O-34, Universal M25XP
Well, Duh!
Loren in PDX
