Bronze vs. Plasitc Thru-Hull Transducers
SteveS
I was hoping for opinions on bronze vs. plastic thru-hull transducers. Raymarine told me to use plastic for fiberglass sailboats. Others have stated that they only put bronze through their hulls. I am pulling the boat for a bottom job and want to replace thru-hulls with the appropriate options. Thanks in advance.
Steve Slaughter
E27
Try using the little "search" icon, upper right part of this page-- there may be info in other message threads on this large site.
Either material should be strong and durable.
Some sailors like the nylon/plastic composite types because they do not want any risk of electrolysis. While I have read of a near-sinking due to bronze thruhulls (and the prop and strut!) being consumed, the article did not mention whether the transducers were also affected.
I have always used the "plastic" versions, on the Standard Horizon instruments on our prior boat and on the new Raymarine ST60's on the present boat.
I figure that the whole boat is made out of reinforced "plastic", so why worry about these items.
Loren in Portland, OR
