Great point.
If one were to plot boat-speed against wind angle, you get what is called a "polar diagram"
Sailing at an angle like "B" feels fast. Sailing at a wind-angle like "A" feels slower (in fact, *is* slower, according to the knotmeter), but gets you to a weather mark faster. Because it is the best "VMG" - Velocity Made Good toward the mark.
You can play with your angles by setting your GPS to a waypoint directly upwind. Assuming there's no current to interfere, sail at different angles, and notice which one shows you the best "SMG" (Speed Made Good) toward that waypoint on the GPS. Whatever angle maximizes SMG will be your optimal close-hauled angle for that breeze.
If you note your boat-speed at that angle, you can start to develop a set of "targets"... as in, sail the boat a little low out of a tack until it is up to (or above) that target, then come up to your close-hauled angle. If your speed drops below your target, you're probably sailing to high; if you go faster than your target, you're probably sailing too low.
It's a useful thing to have in your thinking. But, be aware, getting hypnotized by the knotmeter (aka "chasing the numbers") is not generally a winning strategy. Far better to use that as a tool to develop a feel for when the boat is in the groove.
$.02
