cubby holes
The bases of my cubby holes have some rot. My plan is to remove what rotted wood I can, fill in those areas with either resin or wood filler, and then line the base of the cubby holes with Polyethylene, this is the same material used for dishwasher safe cutting boards. It comes in sheets 1/32" thick. It's indestructable, very easily formed, and inexpensive. I'll adhere it with epoxy, and form it so any water entering the cubby hole, drains out....by the way, anyone know where the cubby holes drain? Anyway, this should work, and it should look good.
