SurabyaKid
My winter project has been building companionway doors. I'm to the point of mounting the hinges for them and was looking for insight/advice. The attached picture was taken during the first pass fitting and since then I have mounted the teak weather strip pieces in front and back that cover the seam between the two doors.
The hinges are the snap apart type that I think Loren posted here a while back. To clear the hatch board slide rail (the teak edge piece) the hinge will have to be mounted fairly close to the edge of the fiberglass bulkhead. On the interior side of the bulkhead, surrounding/framing the companionway, there are three solid teak pieces approximately two inches thick and deep.
I am thinking to drill through the fiberglass bulkhead and use one inch wood screws to anchor the hinges in the teak. I was also thinking to use silicon caulking in the holes prior to screwing everything into place.
Any advice/thoughts would be very welcome as I definitely want to get it right the first time and have not mounted anything in that location before.
Pat
Pat
