Bravo! A good radio is a beautiful thing.Big deal, Jeff. I installed a new VHF radio this weekend.That’s some fine work man. Quite a detailed project. Well done.
Jeff, in reference to the picture above (post#183), any chance you can change the position of the u-bolt around the pipe to what is shown in post #182?
In post 182, tension on the turnbuckles opposes the torque created by the weight of the riser.
In post 183, tension on the turnbuckles ADDS to the torque created by the weight of the riser. I think this is opposite of your original intention.
Exactly!@bigd14
Doug, Is this what you mean?
Correction: Loren has spoken of relocating the FUEL filter.. . .
Loren speaks of relocating the oil filter outside the engine compartment.
Looks good, Jeff. You've made the most from what Bruce King has given you.
I'd be a little nervous about your raw water strainer placement which I guess is several inches above the water line and therefore subject to air leaks at the hose connections or cap when the engine is not operating. But it should be easy to manually prime before starting after a haul out or impeller change. Also, that's a lot of water to drain out before checking the impeller. Just another example of everything is a compromise.
Any difficulty with oil dip stick access under the overflow tank?
Best idea ever! I had to build a fancy 2-way inlet pump valve to be able to do an antifreeze flush without disconnecting hoses.A bonus was that during winterizing it was really easy to close the thru-hull and just pour anti-freeze in the strainer while the engine is running.
THAT is a nice bonus. I'm still working on a way to make my winterizing procedure easier.A bonus was that during winterizing it was really easy to close the thru-hull and just pour anti-freeze in the strainer while the engine is running.
@peamanHi Seven,
Regarding the strainer height, yes to what you say. On the other hand, a leak there is less likely to drain the boat. A bonus was that during winterizing it was really easy to close the thru-hull and just pour anti-freeze in the strainer while the engine is running.
Dip stick: No, but it is a pain to get past that cable. (I can't remember if it's throttle or cut-off.) At any rate, I'm trying to be Zen about it.
@peaman
Boy, I was flying too low and too fast.
Steven!
And I meant to attach this image.
Yeah I scratched my head on this at first but then after not looking at it for a couple days I realized it wasn't so hard.Ken, I don't have the engineering chops to do that, but if someone does, I'd be interested in seeing the results.
