Thanks for the welcome
I'll post some pics when I can. Looking forward to sailing her this summer.
She needs a bit of work to get her up and sailing but I'll plug away at it, part of the fun.
Here is my list of things to do, might as well make the list for all to see and I can keep track on the site as well:
- First get the radio transmitting. Going to start with a new PL-259 connector on the antenna cable - corrosion evident. (she receives well with the center only connected, doesn't receive with it fully connected and screwed on). No transmit.
-new shackle on anchor - corrosion.
-buy 6 new flares
-Rig up a reefing system - main is in good shape - has only one but deep reef. There is a block and cleat on the mast that will work for the clew, and another block and cleat on the mast I could use. The main halyard winch is mounted on the mast. The winches are old ratcheting types but work well.
I don't plan on leading all lines aft at this point.
-rig up a downhaul for the foresail. This line I will run aft to the cockpit.
-she only came with a Genoa. Purchase a used working jib. I think I have a line on one for $200. Has one reef. Hope I can get it.
-Put a block system on the topping lift. Right now it is not adjustable. Far from ideal.
-Put a block on the outhaul. Right now it is not adjustable.
-Draw out a wiring diagram
-Has a Honda 9.9 with alternator. It is charging fine. Needs a new disconnect if the motor is to be removed for service. Right now it is wired direct but does have overcharge protection at the batteries. Someone suggested a trailer tail light connector for the disconnect. Will look into Honda part.
-Find the spark plug wrench if it has one - or get one - and a couple of new plugs and check gap.
-remove life lines. Everyone might not agree with this. I mainly single hand and use a harness. I am 6' 2 and these lifelines come up below my knees. I can not put my foot between the cabin and the toe rail as I leave the cockpit as the stanchion is right there - my foot has to go up and over the stanchion, and even then the toe rail to cabin distance is only about 8 inches. One part of the boat I do not like. With this set up you are forced to go up and over the cabin to get to the mast or bow. I know the lifelines could still save me if I was heeled over and somehow slipped to the low side, but I will be clipped on so this won't happen. Perhaps I will rig up lifelines in the cockpit only somehow for when I have guest on my yacht
-rig up jacklines
-repair aft bilge cover supports - only held on with three sides - one side appears to have come out due to rot on the floor. This is one area that concerns me although there is no spongy areas evident went walking on the cabin floor. I haven't spent the time investigating this yet, just put a large board covering the hole. Jeesh does this boat ever have a deep bilge. You could break a leg if you fell through.
-haul out and bottom paint - this will add to the list for sure. Hope she's all ok down there! I bought her on good faith sitting in the water.
-general cleaning inside and out.
-top side paint when I get a chance - she looks pretty rough but the paint that is peeling has plenty of paint below that! Gives her an "well used" look that I don't mind for now ha ha.
-I see some evidence of leakage into the cabin from the fairlead track on the port side...
Bit of a list, I keep you posted on the progress. Any comments welcome.
Cheers
