ligolaiva38
Defective Rigging 1984 E 381?????
I have studied all the rigging postings on this Ericson site and now I started tuning my rig because it hasn't been tuned right for some reason since I had the mast refurbished and new standing rigging installed by the mast rebuilding and rigging company.
As I looked down the mast, standing on the port side, the upper and intermediate shrouds came down the middle of the mast width exactly to the chain plate. Looking at the starboard side of the mast, the upper and intermediate shrouds came down the mast angling to the stern past the mast width several inches which seemed very strange.
After trying to figure out why the starboard shroud was angling backward, it finally became apparent that the chain plate was not in the exact midddle between the forward and stern lower stays chainplates. Instead, it was two inches further back (closer) toward the aft chainplate. On the opposit port side, the upper and intermediate shroud chain plate is in exact middle so therefor the shrouds came straight down the middle of the mast.
When the last rig tuner tuned the rig we noticed that the lower spreader on the port side would losely shift forward and backward when pushing the shrouds forward and backward parellel to the boat. He tightened up the bolts on the spreaders as much as he could, but the port lower spreader still shifted until he tightened up the upper and intermiate shrouds tight-- very thight. I am speculating it was done overly tight to keep the spreader from shifting back and forth. Which now made the interior head door not close and a few other things had chaged etc. When I lossened the back stay 6 turns the door was a bit better, but still couldn't close.
Now I am wondering if that spreader has been damaged over the years due to the starboard shrouds not having the chain plate centered between the fore and aft lowers? Could the tuning be off due to this? Is it twisting the mast and the boat?
Or, Could it be possible that the sturn angling of the upper and intermediate shrouds on the starboard side is on all Ericson 38's or has my chainplate been defectively installed originally off center?
If it has been installed bad what effect does it have on the mast and how dangerous might it be for the mast. None of the rig tuners have ever known or stated that the the starboard upper and intermediate shrouds were angling to the stern because of the chainplate not being centered. Perhaps maybe, it means no effect what so ever on tuning the mast and it makes no difference.
I am wondering how other E 38's upper and intermediate shroud chainplates are installed and if the shrouds are angled or come down straight with the mast on both sides.
I am also hoping to hear from Seth or anyone else on this situation or danger and what can be done to do to correct it if it is wrong.
Thanks a lot for any and all replys.
John
Laiva 1984 E 381
John
Laiva 1984 E 381
