SASSY
Hello to all, I have been a member of this web site since purchasing my E-34 last April. Since then I have used this web site to answere many question about a wide variety of topics. The membership has made the job of restoring my E-34 much easier than going it alone.
I have entered my E-34 SASSY II in the Del sol al sol Regatta from St Petersburgh Florida to Isla Muahra Mexico begining Friday April 24th. For anyone interested you can follow our progress at www.iboattrack.com. I hope to represent Ericson owners well and hope to bring home the winning jug for all those who take time out of there bussy days to post items on this web site to assist us all.
Here is a list of the projects I have completed with the help of the this owners forum:
Engine Services
RE/RE Injectors-Rebuilt Pinellas Diesel Jul-08
Replaced all engine coolant hoses Jul-08
Flushed and changed all engine coolant Jul-08
Replaced oil filter Jul-08
Changed oil Jul-08
Replaced primary fuel filter (Water Separator) Jul-08
Replaced secondary fuel fliter Jul-08
Replaced fuel line (Tank to primary filter) Jul-08
Replaced transfer pump Jul-08
RE/RE intake manifold Jul-08
Serviced intake manifold, intake valves (throtle body cleaner) Jul-08
RE/RE exhaust manifold (de-carb, soda blasted) Jul-08
RE/RE exhaust elbow (de-carb, soda blasted) Jul-08
RE/RE fuel tank (extracted fuel, cleaned tank) Jul-08
Replaced water lift muffler Jul-08
Replaced exhaust hose (engine to through-hull) Jul-08
Changed oil Sep-08
Re/Re prop, installed new 16" 10 pitch 3 blade Sep-08
Instaled Racor 500 FG Fuel Filter Sep-08
Instaled new 3 blade 16" 15 pitch prop (General propeler) Sep-08
Repacked packing gland Apr-09
Installed new bearing on line cutter Apr-09
Propane service
Pressure tested LP system Jul-08
Replaced LP gas sniffer Jul-08
Replaced LP fitting at tank Apr-09
Hull/Deck
Re-bedded 7 lewmar opening port lights Jul-08
Replaced 9 lewmar opening port light lenses (OEM Lewmar) Jul-08
Replaced 7 inner O-ring gaskets (OEM Lewmar) Jul-08
Installed teak cockpit table Jul-08
Applied 3 coats of teak oil to cockpit table Jul-08
Polished & waxed deck & cockpit Jul-08
Insatled new hose from chain locker to through hull Aug-08
Instaled new through hull fitting at anchor locker Aug-08
Installed stainless steel deck plates at anchor locker Aug-08
Installed Pad eye at anchor locker Sep-08
Replaced lenses in all three Lewmar super hatches(FL Hyu,Rig) Sep-08
Installed new Bimini Sep-09
Installed new dodger Apr-09
Repaired blister in hull, and delamination on rudder Apr-09
Peeled hull and refinished with 2 coats Endura high bulid epoxy Jan-09
Finished hull with 4 coats of Hawk none ablative bottom paint Mar-09
Installed two lazaret latches Apr-09
Minor Gel coat repairs Apr-09
Sails/Rigging
Replaced all running rigging (stay-set) 2007
Head sail cleaned & serviced (Doyle Ploch Sails) Jul-08
RE/RE Boom, buffed, polished, and waxed. Aug-08
Replaced outhaul line Aug-08
Replaced outhaul shiv, and outhaul slider Aug-08
Replaced topping lift line Aug-08
Installed life netting bow pulpit to mid ship gates port/starboard Aug-08
Installed 4 Garhauer furling blocks, Harken lead block Sep-08
Replaced all standing rigging (JSI) Apr-09
Replaced roller furling Furlex (JSI) Apr-09
Replaced 2 shiv pins Kenyon Apr-09
Replaced all 4 shivs(Garhauer full bearing shive) Apr-09
Installed 4 new Garhauer clutches with alluminum backing plates Apr-09
Installed 12 new Garhauer mast blocks Apr-09
Installed new Garhauer main sheet blocks Apr-09
Installed new Garhauer main boom vand fiddles Apr-09
Installed new mast boot Apr-09
Installed new winddirection unit at masthead Apr-09
Installed new mast boots/seizing wire Apr-09
Applied three coats of All Grip toch up paint to mast Apr-09
Applied 4 coats of marine grade polymer wax to mast Apr-09
Installed new main full batten loose footed main sail (JSI) Apr-09
Installed Jack lines Apr-09
Installed wisker pole stantion mounted chaulks Apr-09
Installed teak securing plank port side Apr-09
Wiring & Electrical
Starting battery (WM Group ? ???Amp12 v starting) Jul-08
Installed 19" Polaroid LCD Flat screen TV Jul-08
Purchase 50' Shore power cord, shore power extension Aug-08
Instaled New ICOM VHF cockpit radio Apr-09
Installed new VHF Radio antena Apr-09
Installed new VHF coaxial cable mast base to antena Apr-09
Installed new mast head light Apr-09
Installed new steaming/deck light Apr-09
Serviced windex mast head unit (no faults found) Apr-09
Installed 4 blemished deep cycle 115 batteries Apr-09
Combined bank 1& bank 2 into one house bank Apr-09
Moved bank 2 to shaft access compartment Apr-09
Installed Xantrex 1500 watt invertor Apr-09
Installed new sony stereo Apr-09
Installed Xantrex link 20 dual battery monitoring system Apr-09
Pluming & Water
RE/RE starboard fresh water tank Jul-08
Installed inspection port starboard fresh water tank Jul-08
Flushed & sanitized port, starboard, and bow fresh water tanks Jul-08
Instaled new Whale gusher galley foot pump MK111(Fresh water) Jul-08
Replaced intake hose from through hull to head Aug-08
Instaled chemical unit in line between head and through hull Aug-08
Installed new 3.5 gallon pm Jabsco fresh water pump Apr-09
Installed new fresh water accumulator Apr-09
Installed new shower head and hose Apr-09
Dinghy & Engine
Purchased Dinghy Sep-08
Purchased Engine Sep-08
Again Thanks to all who contribute.
Engine Services
Changed oil Jul-08
Changed oil Sep-08
Propane service
Hull/Deck
Sails/Rigging
Wiring & Electrical
Pluming & Water
Dinghy & Engine
