"Scotty, we need more Power!"
Many years ago experienced sailors advised me to avoid being/going out when the wave height and period were approaching "square."
i.e. when the period (time between crests) was the same number of seconds as the height in feet, any small craft would start to really slam into them hard. That's also when they start to break regularly.
So a sea state of, say, 5 foot waves is nothing when they are over 10 or 12 seconds apart, but when the time drops to 5 to 7 seconds, it gets really rough.
Annecdotal story: one memorable trip north from Astoria to the Straits was aborted at the end of a
very long day, only 48 miles up the coast, when we finally reached off and went into Grays Harbor at sunset.
42 foot boat (!) and we were making
very slow progress north in seas of approx 7' X 7 seconds, all fricken day. Green water down the side decks and over the cabin top regularly.
We had up a small part of the furling main and were motor sailing about 30 degrees off the true wind. No danger, sunny day, and steady summer winds to around 25. Also, in those conditions there was also a contrary surface current of about a knot.
The flexing of the big ol' Cat___a 42 hull caused a steady trickle of water around almost every hatch and port light. (sigh...)
Nice boat for protected waters, but it was somewhat outside its "design envelope" - no safety issue per se, just a day of bracing and hanging on. Diesel was reliable and we were both suited up and dry.
Hard to hang on when going below in a cabin that is 14 feet wide -- long way to fall once you lose your footing.
Skipper stayed in that port for several days and the sea state subsided and he continued on north for a nice summer's cruise in Puget Sound.
Of course if we had been
running in those conditions it would have been a wonderful ride!
Something with a more sea-friendly beam/length ration like the classic Bruce King Ericsons is more comfortable and safer in those conditions. "Comfort" being a relative sort of thing!
By safe, I am not talking about the boat sinking or anything, but the better the "comfort factor" the safer the boat is because the crew is better able to respond to any event onboard before it does become more serious.
Speaking of stories, I recall that a good friend of mine made several trips up that same coast in the 80's with his E-27. He had replaced a deceased A-4 gas engine with a new 9 hp single cylinder Yanmar. He later said that he probably should have gone with the two cylinder, because he spent several hours one rough trip at almost a standstill -- big square seas that kept halting progress, and it took the small diesel a bit to get the boat back up to speed before the bow banged into the next wave.
