On my Ericson 36 RH I removed the sea hood over my compainionway sliding door. I wanted to rebed some screws and replace the weathered caulking around the edge. Once I had it off I discovered something peculiar. There seems to be no drainage for water trapped under the sea hood. This is a problem because trapped water under the hood has found its way into the screws that hold it down and that water is dripping into the main cabin and softening the balsa core in the deck. Has anyone noticed this on other Ericson models, and what have you done about it (or is this simply a design flaw)?
Steve Schwartz
Steve Schwartz
