Hello All,
I never motor very far, maybe a half hour or so at a time so I never really work the Universal 5432 in my E38 very hard or long. Well, I had to motor for about 1.5hrs on Monday to get where I was going and the engine ran pretty hot. Normally I don't run much above 2200rpm as I don't have to. This time I was running against a current and had to push her to 2600rpm to make any decent headway. After about a half hour the temp gauge was showing 200*F. I backed down to 2000rpm and the temp dropped to maybe 180*F. I pushed back to 2200rpm and the temp popped back up to 200*F. I kept an eagle eye on the gauge and ran like this. Running at 200*F is no big deal in the short term, I know this from automotive experience however I know that its not right and needs to be fixed. There was a bit of steam coming from the exhaust but there was plenty of water pumping out.
Today I disassembled the cooling system. The raw water pump is fine, impeller is in perfect shape. Removed all the raw water and coolant hoses, no obstructions. Removed heat exchanger and it too was clean, no buildup at all, its a 3" round unit. The exhaust elbow was replaced by the PO, its a new Westerbeke stamped unit. The rest of the exhaust hose looks very recent.
The one thing that was not "correct" is the water heater was tied into the cooling system inline not in the bypass line as suggested in the threads I searched for info. I have reinstalled most of the hardware but I need to source some 1/2" marine water/exhaust hose to run the water heater line to complete the modification.
Questions:
1. Do I need marine water/exhaust grade hose to run to the water heater or will automotive heater hose do the job? Its just a coolant hose after all.
2. For the people that have performed the "bypass hose" modification to a 5432, did it work long term to control engine temps?
3. Does the smaller hose produce ample heating for the water heater?
Thanks, RT
Questions:
Thanks, RT
