Just a heads up in case anyone else has ezperienced this problem. Or maybe the problem is at my end?
Every once in a while while veiwing different threads, I notice I am no longer logged in.
I assume that you're checking the 'Remember Me' box when you login...so you should have a login cookie written to your box (unless you've disabled cookies in your browser). I know there is a time out issue with iPhones and the iPod Touch...
Are you getting dropped only on dial-up - or on both the broadband and dial-up?
Yeah, that sounds pretty likely - without the login cookie you would be bounced each time the session timed out - with it, you should stay logged in.
Give it a try, and then let me know....![]()
Sean,
Well! I just had an interesting experience. I was just writing a new reply telling you how I spoke too soon because I was dropped when I switched threads. I thought it might be related to my 3G High Speed becomming unavailable about the same time. Now I am pretty sure this must be the culprit since I was dropped again while writing the reply. It so happens my 3G High Speed availability came back on during that time. Problem Solved??? Maybe! If so, sorry for the Fire Drill I gave everyone.
Richard
