I just bought my E28 this July and have a charging question. WHen I first start the engine, the ammeter would only show a slight charge. Not putting too much faith in the meter, I took my analog multimeter and tested the batteries with and without the enging rumming and there seeed to be no difference - just about 12 volts.
Since the batteries never wend dead I knew something was strange so next time out I brought my digital multimeter and got the following readings. Batteries with engine off 12.2 volts, with engine running 12.8 volts. I assumed that I should see 14-15 volts with the engine running and the ammeter should jump up when first starting and slowing go to neutral within a few minutes.
My current plan is to pull the alternator this winter and have it tested.
However, before doing anything I figured I should 'ask the experts'.
Any comments/suggestions are greatly appreciated.
Thanks in advance.
Joe
Thanks in advance.
Joe
