For those of you with a long memory you will recall when I started a thread about filling the deep sump on an E-29 due to the inherent danger of holing the hull threw the aft of the keel.
Unfortunately I had a computer malfunction and lost all of the photos but here are the results.
Material chosen was cement specced for use under water along with acrylic admix. The whole thing took about 40 pounds (dry) of cement mix .
An area was formed for a small sump and base for a bilge pump.
100 pounds of scrap lead was included in the mix in the deepest part on the keel.
After setting for a month the whole thing was capped in Epoxy and mat.
The results were as follows.
Boat has a slower roll period
Boat is stiffer
Can carry more sail ,I reef much later , I can go to wind with more sail and power in stiff winds.
No knock downs which used to be a problem when pushing the boat.
No loss in performance. Still could surf in 15- 20 but control was improved Sailed for 31/2 months in winds to 35 knots in comfort
Now the big kicker . Around Queen Charlotte city I grounded on an uncharted rock. It hit the aft of the keel (just barely)as it is the lowest point .It was on a rising tide so I waited it out and floated off
Dove on the boat when at anchor found about a 3 inch chunk missing of the aft of the Keel, Could see the cement. Repaired with underwater epoxy putty and resumed my trip . It's still there will fix it properly in the spring haul out.
So there it is , If your heading into no-mans land fill that sump unless your feeling lucky. It improved an already great boat
Boat is stiffer
