I did the conversion in my E27. A4 to a Yanmar 2GMF which I believe is very similar to the 2GMF20. I built up the engine mount beds with S4S fir and fiberglassed the entire thing. Then painted with bilge coat. I made a template using the dimensions from the Yanmar manual to get the proper height. I laid down 3/8" aluminum for the engine mounts to sit on and drilled into the new beds. I had to redo this about 6 times. Aligning the engine with the cutlass bearing was extremely frustrating. My template was an extremely accurate representation of the engine, based on the dimensions from the manual but when I put the actual engine in it was always a little twisted and couldn't be aligned the the adjustment in the engine mounts. I even ran a peice of string from where the prop shaft would exit, through to the cutlass bearing and centred using a large washer and tension on the string. I finally got it right and then proceeded to spend 6 hours laying in the quarter berth aligning the shaft coupling.
I replaced all the hoses, added an anti-syphon loop and sea water strainer. I made the raw water intake larger, from 1/2" to 3/4". I also ran new throttle and transmission cables. The direction of the throttle on the Yanmar is opposite to that of the A4 but I got used to it very quickly.
I also has a new fuel made and all new fuel lines and primary fuel filter. New prop shaft coupling, new stuffing box,
new prop shaft, new cutlass bearing and new prop. The engine enclosed will also have to be rebuilt as the Yanmar is taller.
It it is a big job but worth it, I think. I never even tried to use the original A4. My boat was a bailiff seizure so I wasn't able to speak to the previous owner, however, there were maretts used on the electrical connections, the fuel tank had lots of water in it and the engine was covered in rust. The prop shaft coupling was just a large chunk of rust that had to be cut off with an angle grinder. In the end it was all worth it and I would do it again.
Dylan
