E-35 II light problem
Howard Keiper
I'm rewiring an original electrical panel in an E-35-II, 1975, I think, and I'm stymied over where or how the factory routed the wiring for the cabin lights. Anyone know??
Many thanks,
Howard Keiper
Berkeley
Mike.Gritten
Howard,
the wiring for the interior lights is run between the moulded headliner and the underside of the deck. If you need to replace the wire itself, you will have a lot of fun pulling the new runs in. When we did our rewire/panel replacement project a few years ago, these were the only factory installed wires we left in place and have had no problems with them so far. We put our new panel over by the quarter berth and installed a new cable up by the old panel to pick up the existing wiring mentioned above. Maybe not the best way to go, but it was the best way without some MAJOR futzing around with fish tapes and hole saws!
You can see an approximation of the wiring positions in the archived E35 MkII manual on this site.
Good luck!
gareth harris
Howard,
In a number of places (on Freyja at least) the original wires had been stuck in place by the epoxy/polyester which attached the headliner to the deck, so it would have been be impossible to pull the wires through.
I ran all new wires through the cabin, or in some places under the sole.
Gareth
Freyja E35 #241 1972
