klb67pgh
Our E25 just had a door to the space under the sink to access the drain seacock. I have wanted to add a shelf there and finally the off-season task list was short enough that the shelf made it to the top of the to-do list. I've collected salvaged bits of teak and mahogany from other salvaged Ericsons and used a bit for the front lip of the plywood shelf. The plywood is epoxied, and I'll add a mat to prevent the bins from sliding. As you can see, the shelf will house the coffee making equipment. I plan to pick up another clear bin to store cleaning supplies next to to the coffee bin. A 5" wide bin slides out between the sink drain hose and the door frame nicely.
