reginaldobaker
Installing a Nissan 9.8hp onto an E27 and have small questions:
- butyl tape or 4200 for the mount bolts?
Planning to use aluminum (3/16” most likely) for backing plate material:
- should one try to “prebend” the plate to fit the curvature of the transom or not worry about it. I plan to put plate on both inside and outside of the transom and don’t want to crack gel coat or create any “hot spots” of force along the perimeters of the plates
- worth laying any extra fiberglass mat on the inside of the transom for extra strength?
Am looking to optimize the speed of install but don’t plan to cut corners. Optimize for “do no harm” to the transom in case myself or future owner chooses to remove outboard at future date.
thanks for any input
