Tom Prince
I am in the process of replacing the antiquated ball valves with new seacoks and have an E27 specific question. The existing installation of the ball valves is flush mounted, rather than mushroom. When I removed the old plumbing and plywood pads there was a built up lip of fiberglass under the ply. This served to reduce the diameter of the hole for the thru hull from about 2 inches down to either 3/4 or 1 1/4 inches. I am now faced with oversized holes for the actual thru hull threaded piece. The flange part will be fine as the existing cut on the outside is a perfect fit for the flush mount end. Am I making this clear? Anyway I do not want to hollow out the back of the ply as Ericson did to allow a fiberglass dam.. Any experience with this? Probably the same arrangements on the E29.... By the way not one blister, and thats a Hawaii boat!!! Ericson quality hand lay up in 1973.
Tom
Tom
