Results
These are the dimensions of the emergency tiller that came with my 87' 28. Rudder post extension : Material: aluminum, OD=2.3125", ID=2.0625", Length 40"
Slots to engage quadrant, through bolt on bottom. Note: These holes are not directly opposed. The through bolt holes drilled in my quadrant were not directly opposed. Close but not exact. Also in the attached photo note the location of the hole for the tiller handle in relation to the slots. They are not in line as depicted in the drawing above.
Slot depth=6", slot width at the top=0.4375", slot width at bottom=0.6875". Holes at the top for insertion of the emergency tiller handle, 1.25" in diameter, the center of which is located 1.625" down from the top. These are directly opposed.
Emergency tiller: Material aluminum, OD= 1.25", ID=1", Length 40". I drilled a .250" through hole 1.125" from the end. This allows me to slip the tiller into the larger tube and use a wire tie to keep them together. I also wrapped foam pipe insulation around the tiller to keep it from banging around inside the rudder post extension.
