Ah the old lack of maintaince sheave issue
Your sheaves stopped turning at some point, and the wire halyards cut deep groves in them that then allowed the halyard to sink into the sheave. Once the wire rope came out of the sheave at a lower angle because of the groove cut into the sheave, it is now cutting groves in the mast.
Or you have really small sheaves replaced by an earlier owner, from the photos it looks like you have sheaves that quit turning well, and a deep grove cut though.
Take the mast DOWN, have a welder repair the slits in the mast, get some new sheaves from Garhauer, put the whole thing back together correctly. Remember to look at everything while it is down, and to repair or replace everything that you find wrong. This mast is well past it's maintenance point!
This reminds me of a mast that the owner had cut the SS axle in the sheaves in half after cutting through the sheaves. He said that he had wondered why it was so hard to get the sails up.
Also this is a good time to get rid of the wire to rope halyards and get something made in the last century in there. Depending on the use of the boat there are a number of good choices.
