We have a e29 that has been refit with a Universal m25xp diesel. The gearbox has a reduction of about 2:1.
We haven't verified completely, but it appears that we have the original 12x7 prop standard with the atomic 4. This gets us about 4.5kts in calm conditions...ugh.
After some research, it seems the m25 is happiest with about a 15" prop. On our e29, there is only about a 2 finger clearance from the blade tip to the hull with the 12" prop.
Performance propellers recommendation:
Get the largest pitch 12" (maybe 13") prop we can find and live with the difference. Also, go to a 3 blade if we dont mind the loss in sailing performance. They say the 3rd blade is equivalent to roughly an inch of diameter.
They also state there isn't enough rudder clearance to run their 'extendo' prop.
Campbells Recommendation:
we would recommend a
CS12x10x3/4 for your installation. This is a Campbell Sailer, three blade,
Right Hand rotation, 12" diameter, 10" pitch for a 3/4" shaft. This size is
recommended to give you a good cruising rpm and still have reserve for head
wind and seas. We have installed a number of propellers for the Ericson 29
and the better option is to stay with a 12" diameter due to the tip
clearance.
So, what do you guys think??
Also, do other e29s have 3/4" shafts??
Thanks in advance,
Jamin
clearance.
Thanks in advance,
Jamin
