    Join us on September 27th, 7pm EDT
    September Meeting Info
e30+ Steering wheel suddenly rubbing wheel-pilot housing at the bottom.
light24bulbs
E30+ 1984, San Juan Island, Wa
We did a wonderful 12 day trip in BC this summer, and one of the more perplexing things to go wrong on the boat was the alignment between the wheel and the wheel pilot. Rather, the part of the belt housing that attaches to the wheel suddenly started rubbing on the stationary part attached to the binacle, and at the bottom. So the two parts of the clam shell that make up the autopilot housing are rubbing.
Somehow, it seems, either the pilot shifted up or the wheel shifted down, and my vote is on the wheel shifting down, as the autopilot part looks pretty stationary. Now, it only really rubs when turning just to port, but I can tell it's too close at all points of turn. What is it inside the binacle that controls the wheel's alignment? Did something bend? I think if the wheel itself or shaft had bent, it would be wobbling. Instead it appears to just be always angled too far down.
I will happily take the thing apart and learn how it works, but I'd like to have some idea of what I'm going to find.
PS I also noticed that the giant nut which holds on the wheel had come loose about when I noticed the above problem, and I spent the rest of the trip just making sure it was hand tight every few hours. I'm sure that is an obvious clue. I will obviously tighten it back up.
Dave G.
1984 E30+ Ludington, MI
That looks like a Autohelm 4000st ? A little confused by "tiller" pilot in title as that is a wheel pilot. I doubt seriously that the wheel itself has shifted but weirder things have happened. Can you move the wheel up and down or side to side by manhandling it? If not then it's the wheel pilot and maybe it has slipped on the spokes. You can take the wheel off and check if the pilot ring is centered and tight. If it is then most likely something inside the wheel pilot housing itself. They're mostly plastic and do have a known life expectancy and that one has probably exceeded that already :)
Yes, I'd take the thing off the wheel, examine, and reattach. Pretty much self-aligning.
The mechanism is dead simple and if something's wrong it will be apparent. If it's just plastic rubbing, you could sand off the warp, since the housing has big tolerances.
What's inside a Raymarine model:
Phr3d
The little wheels inside the two halves have a shallow bit that has a screw set in it as an axle. When those little bits separate from the clamshell….
So I through-drilled the clam and set the screw through the bit that had broken loose (so the spacing was correct) and onto the clam with a longer screw. Fill the hole on the outside with some sealant.
