Since I removed the glued down sole, I figured I would post some photos of the TAFG structure on a late model E30+. Not sure why they didn't gelcoat the hull section under the settee like all the other areas. Stingy! There is an interesting very slight channel leading directly aft from the compression post to a hole in the TAFG (the brown glue strip I couldn't remove in the photo). I figure it must be some kind of drainage under the sole in case some water gets in. The sole is only 1/4 inch plywood, with 1/2 plywood under that set into the grid compartments. I am going to create three removable sections to replace the old sole.
There are 7 keel bolts. One under the settee, two sets of two in the next two compartments forward, and two singles forward of that.
