Pacific Spirit Marine
I'm looking to install a bus heater into my 1974 E32-200. It has a Universal M3-20B inside. Has anybody done this before? I'm looking for the correct location to port the engine coolant to the heater.
The coolant pump has no extra ports, other than a hose for the coolant bypass circuit. The M3-20B has an external heat exchanger, so I figure that may be the likely spot, but I had a mechanic friend on board the other day, and neither of us could really determine the best spot to pull the coolant. The only likely spot I noted was a hose that exits the exhaust elbow area and goes to the heat exchanger. Does anybody have any experience pulling hot engine coolant for a bus heater or hot water tank installation?
