ratings and racing
Ted, sounds like you got a fair rating-good on ya! On the batten thing-the more battens the bigger roach can be supported (although there are limits on roach area), it also simply provides more support along the leech-but I must say the Chesapeake PHRF either has some typo's in the rule, or has some unusual features to thier version of the rule. Typically the batten limit for a sail that size is 5, and I have already addressed the A-sail luff issue-something is wrong there-I have posted the language used by SoCal PHRF, and either way, yous is close to max functional size, so nothing to worry about on that front.
Shaun-NICE going!!! A couple of thoughts though:
To maximize performance,
EMPTY out the anchor locker-put the anchor, rode and chain on the floor just in front or just behind the mast (put a towel down underneath so you don't scratch the floor). ANY weight up there really hurts performance.
EMPTY ALL the water tanks. Carry gallon jugs of water instead. Just enough for the race, and you can put them where the weight might do some good. When racing, you are not a tanker, right? same for fuel-carry the min required (to get the farthest point away from a harbor to that harbor, plus maybe another 4-5 gallons-no more).
In general-get all uneeded gear off the boat, and work very hard to keep the cockpit lockers and bow lockers as empty as you can-putting things on the cabin sole in the middle of the boat (to the extent you can live with it).
Also, as long as you are under control, the .6 is fine at 25 knots, but you are near the limit. To douse with better control, sail pretty deep and trip the guy and lazy sheet away from the sail at the pole end. Take the lazy guy and pull the sail down BEHIND the mainsail. This should quiet things down as you take it down.
Also, carry some large sheets of Dacron sticky back on board-that would have been a very easy sail repair, and you could have kept the sail in good shape for the whole race..
Make the crew cut their toothbrushes in half-to save weight!!
Do you have a 2 blade fixed? If so, make a mark on the shaft when the blades are vertical. When you shut down to sail, put the engine in reverse to stop the shaft from spinning, then neutral. Spin the shaft to the mark, and lock it in reverse-this will help ALOT. If you need to run the engine while racing to charge the batteries, just be sure to put it in neutral first, and when you shut back down-double check the shaft has not rotated, and lock it back in position.
What was your actual finish position?
S
S
