Jim Picerno
1989 38-200
After reading the many posts on the topic of revising the electrical panel, I’ve finally “girded my loins” (at least figuratively) and started working on a plan. As you can see in the photo, my boat has the original electrical panel. There must have been instruments installed directly over the electrical panel that were covered up by the PO with a1/4” sheet of teak veneer. You can see the cutouts where the various instruments previously resided. Removing the veneer panel revealed the rats nest behind the panel.
Here’s my plan. I want to remove some of the old teak surrounding the removed instruments to have a larger opening to work behind the panel (see photo). I think I can put a piano hinge on the teak veneer piece so it can fold down rather than being screwed. During my cursory examination I know I’ve got a number of circuits connected to the electrical panel which are under fused, over fused, or not fused at all. For instance when I turned on the electronics switch the VHF came on even though the VHF switch on the panel was off. My plan is to go thorough the wiring and connect each device to a fused terminal block with the correct fuse. Then run a wire from the terminal block to the panel. I know this is doubling up on the fuses but at least I’ll know that each device is fused correctly downstream from the panel. I could of course do the same thing but replace the panel with just a switch panel, but I’m trying to do the job correctly while not spending a lot of time and money on this, given I’m working on other projects. This plan would also allow me to replace the panel with a switch only panel down the road. I’m also planning on labeling all the wires. To that end I bought this labeler with some of my “Prime” dollars. Quite a big less expensive than a Dymo and the shrink wraps labels I’ve tested so far seem to be okay. Curious to know what folks are doing for a naming convention. My initial thought was numbers put in a spreadsheet matched to a device. In general am I heading down the right path here? Any gotchas I need to be aware of? Thanks.
