Ericson 25+ Main Sheet Traveller
Bart
There is a molded trough with drainage at cockpit seat level for the track. I suspect a previous owner fitted this entire trough with a piece of mahogony to raise the track so the car would travel unhindered. It was poorly bedded and trapped moisture. Rainwater soaked this wood and leaked into cabin through the bolt holes.
Any photos of what this looked like originally would be welcome.
Bridge deck traveller
My 1983 E25+ has the bridge deck traveller, it has a teak wood base mounted in the channel with the traveler track on top, it is bolted thru the teak and the glass with a nut under the headliner. The car rides close to the surface of bridge. Parts for the traveler are available thru RigRite.
s/v Breeze
