The following discussion is relevant to Ericson 30+ owners:
Image 1 - bow after metal cap is removed.
Now that you know how to do the rub rail joints, the forestay chainplate is screaming for attention. The glass behind it has been crushed and the screw is loose, as if somewhere it bumped straight into a dock or piling. Also needing inspection is why there is a horizontal crease above the screw because this is how the flex area looks before a horizontal crack starts from the screw hole. Seen it.
I would recommend taking the chainplate off, inspecting the back side of it and the hole with a 10X magnifier & dye penetrant, and then seeing what glass damage needs to be repaired behind it. Once removed and because re-rigging will be required anyway, replacing the chainplate as a precaution would not relatively add a lot of cost ($500?).
Sorry
