Ericson 38 stuffing box size
E38
Hi, I am in California and my 1980 38 is now on the hard in Florida, I am looking to order/replace my stuffing box. Pretty sure the shaft size is 1” Does anyone know the stern hose size ?
I tried some searching on words like 'stuffing box hose' and perhaps should have specified 'shaft alley hose' .
Some near-miss comments in this one for instance: https://ericsonyachts.org/ie/threads/stuffing-box-in-the-weeds.21678/#post-175968
In general, do be sure to source a hose made for this exact use. It looks a lot like the usual black rubber heavy duty bilge hose, but is one or two layers thicker. and may also be called packing box hose.
  • Like
Reactions: E38
Alan Gomes
Last year, I replaced my prop shaft, stuffing box hose, and stuffing box. Here's one place where you could source the materials. Gotomarine is another place you could check.
(The link I gave you is for the size of my boat, but you can go from there to find the size for your much larger E38.)
If I had to guess, the stuffing box hose on my boat was factory original. Although it did not leak, I did not trust it, not only due to its age but also because Ericson ought never to have installed such a hose in the first place. (The boat builders of these production boats often cut corners and Ericson was no exception.) Proper stuffing box hose is MUCH thicker than what I took out, as you'll see from the pictures on the site I linked. Yes, it did hold up for many, many years; for that I'm thankful. But granting that it is mission critical and can sink your boat should it fail, it's best to use the correct stuff.
My original stuffing box was actually just fine and I could have continued to use it. But granting the overall costs involved in swapping out the hose and prop shaft (which did have too much wear at the stuffing box junction), I figured I'd put in a new box while I was at it.
  • Like
Reactions: E38
Running universal M-25 what is a good rpm?
This really needs to be asked in a new thread, as the question is not related to this one. This may not seem like a problem now, but will not be easily searchable, going forward.
Easiest if the poster just copies his/her question text and starts a new thread with this as the first post.
