Here and there on my 30+
I know that some were because I just completely recored my starboard deck from the shrouds back to the winches. I have been meaning to take pictures to show you guys but kept forgetting my camera. :loser: I have it now and will take some pics while it is still all open.
As to answer the question, on my 1984 30+ all the lifeline stantion bases were extremely (overly) reinforced.
Under each base the core is plywood and it is drilled out and filled with pure resin where the bolts go through and there is a fiberglass backing plate under all of this.
Very solid ... as long as the genoa track (at the high point of the deck) doesn't leak like crazy
,which has none of the aforementioned improvements except for the plywood core. Hence the replaced (completely shot) deck. I don't know why they didn't do all of the through bolted hardware, or at least the hardware that every model had. I could understand blocks, organizers, etc.
BTW, I mentioned ply core under these components. The rest of the core is balsa.
I have now drilled out and filled all the areas where bolts pass through under both tracks. The winches, shroud bases, deck organizers, etc. were like the genoa tracks. All are being drilled, filled, and rebedded as I go.
I will send some pics of the project. It's been hell but the outcome is great.
-Chris
