Kevin Vine
The forward bulkhead in my '84 Ericson 26-II has developed significant rot at its base, and needs to be torn out and replaced. (This is the bulkhead immediately aft of the anchor chain locker, forward of the V-berth.) I've seen at least 3 Ericsons now with this problem, and I'm hoping that the solution is a wheel that has already been invented...
The rot is likely caused by a faulty seal around the anchor locker and the pulpit fittings... step one of the repair process will be to remedy that.
However, the process that follows is somewhat more problematic. The 1/2' teak plywood bulkhead is tabbed into the hull with fibreglass (rather sloppily, IMHO), and will be a bit of a bugger to remove and replace, as it involves stripping back liner, grinding out fibreglass, and basically creating a bloody mess, all while lying on your back in rather cramped and airless conditions.
Does anyone out there have any suggestions, opinions, warnings, or caveates regarding this pending project?
• I'd appreciate thoughts on tools that may reduce time, effort, and dust.
• I'm thinking that the replacement bulkhead should have a vent installed in the middle of it to allow for air movement in the very confined spaces between the hull, the locker, and the bulkhead.
• While I don't think it does, I'd be curious if anyone else thought the bulkhead might have any significant structural importance.
Thanks in advance for your input!
Regards,
Kevin
Regards,
Kevin
