Fresh Water Pump Replacement
rogerfern
Surflo 200-223-34 water pump gave out on our Ericson 30+, any suggestions on replacement since original model is no longer available?
Thank You
Roger
Hi Roger,
While that model of water pump may no longer be available, Schurflo and Jabsco are both still in business as far as I know, and make decent water pumps. When I have seen them at various chandleries they specified different strengths of water flow depending on how many water taps you have. Most E30+ have one galley and one head tap, so should be easy to find a good pump for two taps, with a similar flow rate to your current pump. Buy one that fits your existing hose and coupler size. I've seen them for about $150 Canadian $.
Hope that helps.
