All,
I can't seem to unfreeze a telescoping arm made up of a 1" boxed anodized aluminum tube that slides into another one.
I've spoken to the manufacturer who offered that all he does in these
cases is to use WD 40 to loosen them. Alas, I've tried that, even using
Gunk brand penetrating oil too as well as heat from a propane torch gently waved at first the entire length of the tubing and then localized in 3" segments. The latter seems to have worked the best yet little movement has been gained. Currently the assembly has been soaking in a one gallon bath of white vinegar in the hope that any mineral buildup
might get dissolved away. That doesn't seem to be working either, as in two days I've been able to pound them apart only about 1 1/2" with about 3' to go.
Has anyone else faced this dilemma? Anyone have an idea or two?
That bath I spoke of consists of a 5' length of 4" ABS pipe capped on
both ends with a 2" open slit cut the length of the pipe. I mention this on
the chance that someone will suggest some form of soaking to release the two boxed tubes.
Thanks in advance,
Glyn Judson, E31 hull #55, Marina del Rey, CA
Thanks in advance,
