mherrcat
As long as you keep in mind that the Garmin speed is "speed over the ground: and not boat speed throught the water.
Seems like for navigational purposes this would be a moot point. Since it is a Global Positioning System it would pretty much eliminate the need to use dead reckoning. And if you really did want to do dead reckoning for some reason, speed over ground would be more reliable than trying to calculate the effect of current drift on boat speed, but it would not take into consideration the set of the current. Either way, the GPS coordinates would tell you more accurately where you are.
The more important thing about transferring GPS coordinates to a chart, especially in some other parts of the world, is that some charts were created based on information collected in the 1700's and 1800's. Water depths and obstructions on the chart may not be plotted with the same accuracy as your GPS coordinates. In other words, your GPS coordinates could put you in a place on the chart that says you have plenty of water under you but you could still run aground.
